LMS Journal Club
What is the Journal Club? The principle is the following: somebody presents an article in details while others interact with him/her to understand the article in details. The goal is to strengthen the scientific culture of everybody by sharing knowledge in a friendly atmosphere. AND, there is free lunch.
We tentatively meet once a month, usually on Tuesday, from 12:00 to 13:00, in the Jean Mandel room. You can subscribe to the journal club shared calendar using this link (do not download and import the calendar, simply create a new remote calendar with this address in order to always get the most up-to-date version).
This year the Journal Club is organized by Filippo Agnelli and Mahdi , supervised by Martin Genet.
Please come and talk to us if you have any suggestions.
Update — Journal Club sessions are back to Jean Mandel room! Come to talk about science and have lunch together!.
Current year's sessions
Previous years' sessions
2020-2021:
- 03 November 2020: Pierre Margerit — [Fang G. (2020), Reinforced FDM: Multi-Axis Filament Alignment with Controlled Anisotropic Strength.]
- 24 November 2020: Marco Moscatelli — [Chesnais C. (2015), Effects of the local resonance in bending on the longitudinal vibrations of reticulated beams.]
- 02 February 2021: Jessica Manganotti — [Politi M.T. (2016), The dicrotic notch analyzed by a numerical model. Comput. Biol. Med.]
- 23 February 2021: Emilien Baroux - [Susmel L., Lazzarin P. (2002), A bi-parametric Wöhler curve for high cycle multiaxial fatigue assessment. Fatigue & Fracture of Eng. Mat. & Str.]
- 23 March 2021: Nikhil Mohanan - [L. Méric, P. Poubanne, G. Cailletaud (1991), Single Crystal Modeling for Structural Calculations: Part 1—Model Presentation. J. Eng. Mater. Technol.]
- 6 April 2021: Antoni Joubert - [P. Geoffroy-Donders, G. Allaire , et al. (2020), Coupled optimization of macroscopic structures and lattice infill. hal-02429166]
- 27 April 2021: Théo Zurcher - [C. J. Todaro, M. A. Easton, D. Qiu, et al. (2020), Grain structure control during metal 3D printing by high-intensity ultrasound. Nat. Commun.]
- 18 May 2021: Chloé Giraudet - [J. Liu, S. Lin, X. Liu, et al. (2020), Fatigue-resistant adhesion of hydrogels. Nat. Commun.]
- 15 June 2021: Mahdi Manoochehrtayebi - [B. Budiansky, E. Kimmel (1987), Elastic Moduli of Lungs. J. Appl. Mech.]
2019-2020:
- 17 September 2019: Lucas Benoit-Maréchal — [Ranguelov B. and Stoyanov S. (2008), Instabilities at vicinal crystal surfaces: Competition between electromigration of adatoms and kinetic memory effect. Phys. Rev. B.]
- 22 October 2019: Estève Ernault — [Wang G. (2018), Lightweight, super-elastic, and thermal-sound insulation bio-based PEBA foams fabricated by high-pressure foam injection molding with mold-opening. Eur. Polym. J.]
- 26 November 2019: François Kimmig — [Caruel M. (2014), Dimensional reductions of a cardiac model for effective validation and calibration. Biomech. Model. Mechanobiol.]
- 21 January 2020: Chloé Giraudet — [Aghamohammadzadeh H. (2004), X-Ray Scattering Used to Map the Preferred Collagen Orientation in the Human Cornea and Limbus. Structure.] & [Wang C. (2015), Evolution and Function of Dinosaur Teeth at Ultramicrostructural Level Revealed Using Synchrotron Transmission X-ray Microscopy. Sci Rep.]
- 25 February 2020: Nicolas Dimov — [Vysotskiy I. (2019), Unusual fatigue behavior of friction-stir welded Al–Mg–Si alloy. Materials Science and Engineering]
- 31 March 2020: Clément D'Hondt — [Szczerba M.J. (2015), Experimental studies on detwinning of face-centered cubic deformation twins. Acta Materialia.]
- 07 April 2020: Martin Avila Torrado — [Bourouiba L. (2014), Violent expiratory events: on coughing and sneezing. J. Fluid Mech.]
- 14 April 2020: Jessica Manganotti & Nicole Tueni — [Mechanical Ventilation for COVID-19]
- 28 April 2020: Alexandre Bleuset — [Ma Z.L. (2017), Harnessing heterogeneous nucleation to control tin orientations in electronic interconnections. Nat. Commun.]
- 19 May 2020: Filippo Agnelli — [Chung H. (2019), Binodal, wireless epidermal electronic systems with in-sensor analytics for neonatal intensive care. Science.]
- 02 June 2020: Marija Gusseva — [Rondanina E. (2020), Evaluation of stimulus-effect relations in left ventricular growth using a simple multiscale model. Biomech. Model. Mechanobiol.]
2018-2019:
- 25 September 2018: Martin Genet — [EK Rodriguez, A Hoger, AD McCulloch (1994), Stress-dependent finite growth in soft elastic tissues. Journal of Biomechanics.]
- 22 October 2018: Camille Guévenoux — [J. Gockel, N. Klingbeil, and S. Bontha (2016), A Closed-Form Solution for the Effect of Free Edges on Melt Pool Geometry and Solidification Microstructure in Additive Manufacturing of Thin-Wall Geometries. Metallurgical and Materials Transactions B.]
- 27 November 2018: Federica Caforio — [Rouze, N. C., Wang, M. H., Palmeri, M. L., & Nightingale, K. R. (2013), Finite element modeling of impulsive excitation and shear wave propagation in an incompressible, transversely isotropic medium. Journal of Biomechanics.]
- 18 December 2018: Laurent Guin (for the forth year in a row !) — [Rosakis, P., Notbohm, J., & Ravichandran, G. (2015), A model for compression-weakening materials and the elastic fields due to contractile cells. Journal of the Mechanics and Physics of Solid]
- 29 January 2019: Yanis Balit — [Munier, R., Doudard, C., Calloch, S., & Weber, B. (2016), Determination of high cycle fatigue properties of a wide range of steel sheet grades from self-heating measurements. International Journal of Fatigue]
- 26 February 2019: Nicolas Hanappier — [Thomas, J.D. and Triantafyllidis, N. (2009), On electromagnetic forming processes in finitely strained solids: Theory and examples. Journal of the Mechanics and Physics of Solids ]
- 26 March 2019: Nikolai Khailov — [Liu, L., Kamm, P., García-Moreno, F., Banhart, J., & Pasini, D. (2017), Elastic and failure response of imperfect three-dimensional metallic lattices: the role of geometric defects induced by Selective Laser Melting. Journal of the Mechanics and Physics of Solids ]
- 23 April 2019: Matthias Rambausek — [Bossavit A. (2012), The premetric approach to electromagnetism in the ‘waves are not vectors’ debate. Advanced Electromagnetics]
- 28 Mai 2019: Filippo Agnelli — [Graeme W.Milton & Robert V.Kohn (1988), Variational bounds on the effective moduli of anisotropic composites. Journal of the Mechanics and Physics of Solids]
- 25 June 2019: Ludovic Gil — [Lopez-Pamies O., Ponte Castaneda P., Idiart M. I. (2012), Effects of internal pore pressure on closed-cell elastomeric foams. International Journal of Solids and Structures]
2017-2018:
- 24 October 2017: Laurent Guin — [James K. KNOWLES (1978), On the dissipation associated with equilibrium shocks in finite elasticity. Journal of Elasticity. ]
- 28 November 2017: François Kimmig — [P.S. Koutsourelakis (2009), A multi-resolution, non-parametric, Bayesian framework for identification of spatially-varying model parameters. Journal of Computational Physics. ]
- 19 December 2017: Foucault de Francqueville — [M. D. Rintoul and S. Torquato. (1996), Computer simulations of dense hard‐sphere systems. The Journal of chemical physics.]
- 16 January 2018: Othmane Zerhouni — [R.S. Lakes, W.J. Drugan (2002), Dramatically stiffer elastic composite materials due to a negative stiffness phase? JMPS ]
- 13 February 2018: Alexandre Jouan — [E. Charkaluk, A. Constantinescu, F. Szmytka, S. Tabibian (2014), Probability density functions: From porosities to fatigue lifetime. International Journal of Fatigue ]
- 13 March 2018: Dipayan Mukherjee — [Chad M. Landus (2002), Fully coupled, multi-axial, symmetric constitutive laws for polycrystalline ferroelectric ceramics. JMPS ]
- 17 April 2018: Ludovic Gil — [Shawn A. Chester, Lallit Anand (2011), A thermo-mechanically coupled theory for fluid permeation in elastomeric materials: Application to thermally responsive gels. JMPS ]
- 5 June 2018: Sofia Sakout — [W. T. Read and W. Shockley (1950), Dislocation Models of Crystal Grain Boundaries, Physical Review ]
- 12 June 2018: Nicole Tueni — [Sommer, G., Haspinger, D. C., Andrä, M., Sacherer, M., Viertler, C., Regitnig, P., & Holzapfel, G. A. (2015), Quantification of Shear Deformations and Corresponding Stresses in the Biaxially Tested Human Myocardium, Annals of Biomedical Engineering ]
2016-2017:
- 9 November 2016: Laurent Guin — [Kankanala & Triantafyllidis (2004). On finitely strained magnetorheological elastomers. Journal of the Mechanics and Physics of Solids.]
- 29 November 2016: Florent Wijanto — [Viswanathan, Sundaramb & Chandrasekara (2016). Stick-slip at soft adhesive interfaces mediated by slow frictional waves. Soft Matter.]
- 13 December 2016: François Kimmig — [Cohen, Mouterde, Quéré & Clanet (2015). Capillary muscle. Proceedings of the National Academy of Sciences.]
- 17 January 2017: Alexandre Jouan – [Williams (1952). Stress Singularities Resulting From Various Boundary Conditions in Angular Corners of Plates in Extension. Journal of Applied Mechanics.]
- 14 February 2017: Anthony Janin – [Dai, Dair, Dai, Ober, Kramer, Hui & Jelinsky (1994). Reinforcement of Polymer Interfaces with Random Copolymers. Physical Review Letters.]
- 21 March 2017: Andrei Constantinescu — [Milton & Cherkaev (1995). Which Elasticity Tensors Are Realizable? Journal of Engineering Materials and Technology.]
- 25 April 2017: Othmane Zerhouni — [Levitz (1995). Off-lattice reconstruction of porous media: critical evaluation, geometrical confinement and molecular transport. Advances in Colloid and Interface Science.]
- 24 May 2017: Special Journal Club CSMA'2017
- 7 May 2017: Anchal Goyal — [Kammers, Wongsa-Ngam, Langdon & Daly (2015). The microstructure length scale of strain rate sensitivity in ultrafine-grained aluminum. Journal of Materials Research.]
- 20 June 2017: Erato Psarra
2015-2016:
Journal Club Hall of Fame (3 presentations or more)
- 4 presentations: Laurent Guin
- 3 presentations: François Kimmig
